- 10:33 PM
- Jan 24, 2018
- Extreme Southeast CA
Cool, interesting, thanks
Looks to be hard on roads as well.
I've found white oak challenging in that way. I did 5 recently, and still don't have a good method dialled in.Those darn short fiber trees like gravity too much. They never initiate the fall until you’ve already taken too much hinge. Then it just tears sideways and goes straight for the lean.
Yup I don't loose anything according to the log buyers to this point as I do try & keep the hinge out of the "money" and in the trim. AND those larger trees can be a pita to trim root flares after that side is on the ground. So by doing that I'm not only having a lot of face angle to keep the hinge from going into tension when the face closes, but I don't need to try and trim THAT side when its face down on the ground. Which often would drag a trench when I skid as well, a third reason I do what I do. Also some tree's don't need the open face, you might see other types of cut on the channel from bore cut everything but three points, do vertical cuts on those "root flare " locations to release the tree. Usually don't show that type of thing on the channel. Don't want folks attempting w/o understanding of the physics .As I recall, he trims a flare off vertically to function as a shallow face and doesn’t lose wood from the log.
I have to say I have seen some very nice felling cuts on your channel.Yup I don't loose anything according to the log buyers to this point as I do try & keep the hinge out of the "money" and in the trim. AND those larger trees can be a pita to trim root flares after that side is on the ground. So by doing that I'm not only having a lot of face angle to keep the hinge from going into tension when the face closes, but I don't need to try and trim THAT side when its face down on the ground. Which often would drag a trench when I skid as well, a third reason I do what I do. Also some tree's don't need the open face, you might see other types of cut on the channel from bore cut everything but three points, do vertical cuts on those "root flare " locations to release the tree. Usually don't show that type of thing on the channel. Don't want folks attempting w/o understanding of the physics .
Another point that has come to my attention is about saw weight, Doing what I do doesn't require me to be shimmy shake hustling around the tree as I work around the back cut. Face cut from one side where the cut is a down cut on all but the hill sides where Humboldt's happen & work from the other side from one position to bore cut all the way thru and then cut back to the hinge, THEN stand up looks & let the trigger go. During the bore cut the saw is in the tree, Weight doesn't matter as much, why the g395 was a favorite, power is. When I go back to my "old" ways , weight is everything as I don't move as a kid anymore. and don't like moving around the tree all bent over.
Why do u use it?I think I’m going to call it the crush face
Bear claw face?
Maybe you just got lucky on that one?I think I’m going to call it the crush face
Bear claw face?
What were you thinking when trying that?
From the same job.I have always wanted to go to Canada and be a west coast faller.
Today my dream came true, except I only had to travel as far as county sligo and not vancouver island.
View attachment 440888View attachment 440889View attachment 440890View attachment 440891
Ms 460 with 28 inch bar doing the job. I could have done with a much longer bar to be honest but my 30 inch bar isn't fixed yet and the 084 with 36 is just to heavy and awkward for using in tight spots like that.
Roscommon.Darklord, what county are you in? My family came from Tyrone I believe.
