Trees you've cut
Maintenance Chief
10:52 AM
South Carolina
That pine had some massive growth rings starting about year 8 or 10. Must have had some trees thinned around it.
Probably about the time it found the drain field in the yard! Those are some of the biggest/healthiest trees I've cut down.
HumBurner
7:52 AM
Humboldt
HumBurner
7:52 AM
Humboldt
Fat growth rings are not an inherent sign of a good, healthy tree.
They often outgrow themselves and end up with all kinds of issues/weaknesses. Plus it's poor quality lumber/firewood.
Maintenance Chief
10:52 AM
South Carolina
I've cut some huge trees that plunged into block sewer tanks,drain fields,distribution boxes, and pond treatment.
Poor quality is not what I'd use to describe them, Super charged would be more accurate.
Catbuster
Roadbuilder Extraordinaire
10:52 AM
Lou, KY
With 60 sustained and 80 gusts the entirety of southern Indiana and Central KY has turned into one big blowdown patch. That big white (maybe/probably Virginia) pine was a doozy.
Roundgunner
Active OPE Member
10:52 AM
SE CT
First post,,
I took 2 of these white Oaks. Probably the two biggest heaviest trees I've ever cut.
I have some photos of them before they were bucked but not in my phone.
Cut with a 25" 461
10:52 AM
Nice, and welcome to the site. You must not be too far from me, I can almost touch CT (I'm very near the HD on 84).
I bucked these up a while ago (also White Oak) and turned them into firewood for my daughter.
Roundgunner
Active OPE Member
10:52 AM
SE CT
Can't be too far. I'm between Willimantic and Norwich, tiny village of Hanover, part of Sprague. Nobody has heard of any of them.🙂
Roundgunner
Active OPE Member
10:52 AM
SE CT
Roundgunner
Active OPE Member
10:52 AM
SE CT
I go 84 anytime I go west or south unless I have to go to the city. 95 sux every time. I'm a traveling photographer so I do drive a lot. Thank God not as much as 35 years ago! Now I only go to the jobs that pay real well!groton-conn-july-11-2019-command-master-chief-c5c344-1024.jpg
HumBurner
7:52 AM
Humboldt
Really twisted tan oak, moderate-to-heavy leaner, growing out of a cut bank and over a client's driveway. It's not a big tree, but big and twisted enough to have to think on some. It grew up into multiple other trees and it's top rested in some big fir-limbs across the road.
I almost went with a coos bay, but needed a degree of control because of its potential to get hung up. As well, this would have been a candidate for slashing down (giving an undercut, but not a face, to the slash first), except for the multiple twists in the trunk, plus odd limb-weight/placement also ruled that out.
So I landed on giving it a very small face cut ~25% in and at a steeper pitch, flush with the wood. This would still allow a steeper, slashing angle from the top/back cut, while giving the tree a chance to push itself slightly further away from me.
There was another slightly larger tan oak on this stretch of driveway with exposed roots, growing out of a cut bank with less severe lean, but more crown/brush to it with no place for the tree to fall. Slashing would have been a guaranteed chair and possibly pulling the bank out and accelerating the erosion. The footing was poor with only one escape route.
What I opted to do was fall it SLOWLY into a larger madrone to hang it up (don't like skinning madrones, especially, or any tree if I don't have to) to free it from the ground instead of the stump.
From the ground I was able to backbar it safely, letting it drop slowly off the stump and securing it in the madrone. With the butt now on the ground, it was pie-time. Tree top ended up back across the road on its stump, and the madrone only lost some small branch-tops.
10:52 AM
Yea, you are a little ways away, I'm about an hour from Hartford, sometimes go to the Cabela's there.
chiselbit
7:52 AM
Norcal
Here’s a compilation of my apprentice Piper Bateshttps://www.instagram.com/p/CpYmCdMDoEp/
chiselbit
7:52 AM
Norcal
Ok. That didn’t work.
Catbuster
10:52 AM
Lou, KY
More blowdown. A lot of these have been evergreen trees, and between their shallow root systems and them being the only trees with foliage I’m not surprised. This one wasn’t very hard, it broke off ~7’ up, way better than attached to the root ball.
Tons of top bind though. You could bore in halfway through the trunk and feel the kerf closing on your bar, and see one of those closed kerfs bottom right. Lots of ream cutting and the triple tape taper wedges plus my heavy wedge beater are a blessing.
