tree monkey 661 turning 15k?!?!?
Deets066
AKA Deetsey
5:48 PM
we are testing to find the limitations of the coil. it is certainly not rpm. there are some "fixed" parameters you need to learn to work with, not against
This post says a lot.
What your sayin is, if you just swap to a regular carb. You ain't gunna be able to turn serious rpm
paragonbuilder
5:48 PM
Norwich, CT
kinda like what we talked dan about the flywheel is limiting the voltage going to the mtronic carb
the fuel solenoid can only open so far with the voltage produced by the flywheel /coil
So is the default on the solenoid closed? It would need to open more to limit the saw with fuel. Not less...
It could very well just be programmed as a governor at 13.5 or whatever. If it turns faster than the programming allows it opens the solenoid fully to limit the saw.
jmssaws
Banneded
4:48 PM
I've had a carb on one several times and could screw the high shut and not get anymore rpm and so has several other people.
jmssaws
Banneded
4:48 PM
It's not as simple as putting a wj69 on it or everyone that's tried it wouldn't say the same thing.
