redtractor
- 12:06 PM
- Jan 16, 2016
- Maryland
I was given a burnt up 028AV. When installing the new cylinder, the squish w/o the base gasket was .016. Yeah, tight but the big number with it didn't sound exciting. The compression is now 215. Plenty exciting enough but I'd like the crank to stick around so the gasket will go back in.
My question. While at idle and top end it runs fine, it falls flat in the transition and the carb and fuel system have been gone through. Is that ridiculous compression the reason for the bog?
