Adirondackstihl
- 5:37 PM
- Dec 4, 2015
- Upstate NY
I wouldn't want to advance the timing on a milling saw if it were belonging to me.
Is this something that comes from experience or a scary thought? I've wondered about this. Would it run too hot? Or would the enlarged muffler openings increase enough flow to balance that out?I wouldn't want to advance the timing on a milling saw if it were belonging to me.
Milling is hard enough on a saw as it is. Last thing I would want to do is increase internal temperatures, particularly on a milling saw.Is this something that comes from experience or a scary thought? I've wondered about this. Would it run too hot? Or would the enlarged muffler openings increase enough flow to balance that out?
So if it's just speculation then why not put it to the test? I don't see any harm coming to the test subject since it's a test to see if it is able to reach critical temperatures and not withstand them. If it gets anywhere close then just shut it down and it can be confirmed. I've been wondering about advancing timing on large milling saws (880's) with port jobs and this is something that hangs my mind up just the same. I don't have a way to test this out so I can only hope someone else does so we can learn from that.Milling is hard enough on a saw as it is. Last thing I would want to do is increase internal temperatures, particularly on a milling saw.
Cookie cutter, hot landing or felling saw.....well that's another story I guess.
I'll switch between 2 and 4 cycle the next time that I am timing something and see how the mark responds at the same RPMIt doesn't know the difference. It knows the time between the last two pulses and then flashes light X/720 seconds before a predicted pulse. It's 720 because the spark plug only fires once every two revolutions on a four stroke. For a two stroke it would have to be X/360 seconds before or you can just multiple the dial number X by 2.
In a typical car motor, the distributor turns at 1/2 of the crank speed, so I hear what youre saying, but it dont make sense to me in my pea brain.
On 4 stroke OPE, the plug fires every revolution, whether its on the power stroke or the exhaust stroke
But that still leaves the distributor spinning at 1/2 the crank speed in a conventional distributor setupThat's know as a wasted spark ignition setup and would act the same as a 2 stroke according to the dial on the timing light.
A small ignition advance will improve efficiency and reduce heat.Just outta curiosity? Or?
Cause otherwise I see no advantage in advancing the timing on a ported 088/880 just for milling. How much more board feet you gonna get outta that saw and at what expense to the life of the top end. Point of diminishing returns.....
Just my opinion.....
Just wondering if you or anyone else may have a video of how to use a timing light. That way those of us who dont understand them can mabe learn a bit better by a vid.I simply used a timing light , marked a fin on flywheel, mark tdc as shown in my pic above, started the saw (warm), and removed the recoil cover. Trigger the light and mark where it flashes.
Just hook the light to a battery and to the plug lead.
I'm sure there's lots of them on utube.Just wondering if you or anyone else may have a video of how to use a timing light. That way those of us who dont understand them can mabe learn a bit better by a vid.
Thanks
rotate yr key and its back to stock.Most saws benefit from a little advance, but if you dont notice a better cutting machine, its only a dollar or so for a new keyway and youre right back to stock
