This MFing clamshell...
dmb2613
7:05 PM
Randolph Virginia
The so-called gasket sealer that I ran into was the same color as my permanent thread lock adhesive. Frankly, guys, I am surprised I was able to break it loose. And, I had to rebuild with the clutch still in place because that was impossible to remove. My gut feeling is that the clutch was also secured with thread lock adhesive.
I know this is an old post, but how did you do it with the clutch still on, what about the oil pump, I call fowl no way to do it
Wood Doctor
Edwin
6:05 PM
Omaha, Nebraska
The flywheel has to come off, but the clutch can stay on. It's much easier to pull the engine with the clutch off. Somehow I did it with it still attached. I believe the pan, bearings, seals, and drive shaft all stayed in place.
