Thick and durable handle wrap?
MtnHaul
7:00 PM
West Coast Mtns.
A few days ago I tried wrapping the handle on my 261 with about 12ft of silicone tape and it made a small difference but I would really like to fatten up the handlebar for a more comfortable grip. I don't have giant hands but neither do I have midget hands. The silicone tape seems to work well and I managed to find a shade of orange that almost looks factory, but it did very little to fatten the grip. I was thinking of first wrapping with some cushy bike handlebar tape and then going over it with silicone tape for durability. Any slick solutions out there I might have missed?
heimannm
9:00 PM
Dike, Iowa
I think you will find that the silicone tape is not very durable. You need something on top of it to provide some physical toughness.
Mark
Beauman
9:00 PM
Little Falls, MN
Damn tough to find something that's durable, color fast, etc., so don't have too lofty expectations, but they're chainsaws....meant to get dirty and beat up. Funny that you just posted this, as I've been busy upgrading the handles on most of my saws for improved comfort and grip. I even posted a video showing the stages and end result. Check it out at
Here's my process and choice of materials: Remove handle from saw, and degrease the handle with rubbing alcohol. Then wrap paracord (with innards removed) to create flattened grip ridges that will underlay the wrapping materials. Then use tennis racket over grips (which aren't durable by themselves, and usually requires 2-3 to fully cover a std handle, twice that for a wrap handle), and if you want extra cushion, then double, or even triple-up the over grips. Since I have so many saws, I ended up buying a pack of 30 over grips. Then top the over grips with 1-2 passes of hockey tape, which you can find in a bunch of colors to your liking (don't use athletic tape or anything with a crazy amount of adhesive). With the over grip and hockey tape wraps, make sure you apply enough tension to keep the material from creating creases.
I find the foregoing provides good grip and more comfort from the stock handles, slightly reduces vibration if I put enough over grip material on, and best yet, the adhesive isn't crazy so if the wrap gets damaged etc. beyond your liking, very easy to remove and reapply a new wrap. All told I can have a full wrap handle upgraded as described with 30 minutes. I wrapped a bunch of saws, and cost worked out to about $16.60 per handle.....not bad IMO. I'm hoping each wrap will last many years before I have to replace.
MtnHaul
7:00 PM
West Coast Mtns.
Well so far I've been very happy with a handlebar wrap consisting of a layer of 1" silicone tape overlapped by half the width and then covered with hockey tape overlapped by half the width. Grip is now nice and fat with a little bit of cushioning.
EFSM
9:00 PM
Extreme southern IL
Has anyone ever tried using heat shrink on handlebars? It seems like the stuff with glue should work but I’m not sure how durable it would be. IMG_1038.jpeg
singinwoodwackr
8:00 PM
moon
Has anyone ever tried using heat shrink on handlebars? It seems like the stuff with glue should work but I’m not sure how durable it would be. View attachment 484893
I tried 3 different brands of shrink off ebay. cut them all off after they failed to actually shrink around the curves of the handles. And, when done, the material is a lot harder than stock rubber so the anti-vibe factor is actually worse.
I have leftovers if anyone wants it, lol
EFSM
9:00 PM
Extreme southern IL
Could you post a picture/ad of which style you used? This 3:1 or 4:1 stuff is significantly thicker/more flexible than older 2:1 stuff.
dangerousatom
10:00 PM
Quakertown, PA, United States
Find a length of 1-1/4" underground heat shrink tube. Underground is thicker and hot glue on the inside. If you want a lil "cush" first wrap the handle with some 1/16" thick single sided adhesive foam tape. Any good electrical supply place will have the tube, usually its only in 12" lengths, but Ive found it onlie in 24-36"
Done & Done
If you wan tot go fancy and have the time get a real thick leather steering wheel cover that is stitch on and shrink tube the ends after stitching.
singinwoodwackr
8:00 PM
moon
3 and 4:1, 1.5”, 2” glue lined…
The cross hatch was the worst...absolutely junk.
EFSM
9:00 PM
Extreme southern IL
If you want damping and cushioning as mentioned, a cork lined bike tape works well and fairly durable, View attachment 486713
Looks nice. However, I was after max durability and something that for sure wouldn’t turn on the handle. The giants that run this saw tend to twist the rubber on handles.
singinwoodwackr
8:00 PM
moon
