Wonkydonkey
Plastic member
- 4:11 PM
- May 14, 2017
- Sussex, UK.
I didn't know they did that. I've always wondered about steel core bullets. Now I want some.
It's just a soft steel core.
YIKES!!!A while back I milled the top off this ash, I noticed something, thought a washing line or something. It was approx 6-8ft up the tree, but in the middle of the log while milling.
My mill wouldn’t go any wider. And that was it for the day.
View attachment 286042 View attachment 286043
Good point.It may be mild steel, but it still penetrated our helicopters very well in 'Nam. I remember seeing my first one and the core was bent and damaged. I thought that the NVA didn't know how to make a proper AP projectile.
It was only later on, after I studied the cartridge, that I understood the genius of the round. It was INEXPENSIVE, even the case used mild steel. The BC was very high and the inexpensive steel core was positioned in the back of the round to give it more stability. The front of the core was flat, that left a cavity at the front of the projectile. That cavity would tend to collapse when it hit, which turned the round into a 'dum-dum'. Not only was it hard hitting for it's velocity, but the steel core could keep on penetrating. - Rather than being a piece of junk, the Russians had put some thought into it.
I believe I have some tungsten core .277 Barnes bullets that have since been discontinued. I bought several boxes of them when they were discontinued. They are shorter than the all copper bullets of the same weight and will stabilize better.
even though the steel jacket is copper washed.
Good point on that powder. Some of my buddies shoot trap They use every shell known to man. Wolf brand shotgun shells perform fine but they’ve told me the powder is just very dirty. They clean them up after every shootThe stuff I ran into was not 'copper washed' it was fully jacketed in a copper jacket. The jacket would peal off and the steel core would continue to penetrate. There was no possibility of the steel core being able to touch the rifling.
Another thing was the chrome bore. Since a priority was being inexpensive, the rounds used the cheapest powder, which was a corrosive powder. The chrome bore allowed them to use the cheap powder as it would not corrode the chrome bore.
Some guys in Oz used a conversion chamber that allowed them to use the 7.63x39 rounds in their .303 Enfields. However, they had to clean their barrels after every shoot to avoid the corrosion.
Be truthful, you want to find powder at what it was before.I just want to find some powder...
Not familiar with it, but then again I'm not familiar with any of them, I haven't reloaded since I was 15. I just shoot them, I find whatever I need.I want to find shooters world match or some varmint. I haven't found any what so ever.
I have no idea, been way longer for me.So, what is a pound of Red Dot going for nowadays?
I haven’t loaded a 12 ga in ten years.
The last I found made reloading very economical. Still have a tub left. As far as actual numbers I honestly cannot remember. I know it was a pain to try to find it.So, what is a pound of Red Dot going for nowadays?
I'll ask around a bit, do you have an FFL by any chance.
I'll run about anything in most mine, if I can hit a pie plate at 10 with the pistols or one at 100 with the rifles I'm fine.Nope no FFL, But I've seen very good results online for this powder in both my match 223 and 6.5x47L. Which is mainly what I would use it for and reload for.
Right now I'm using CFE223 and RL-17, but I would like to condense to a singular cheaper powder.
RL-17 was for awhile, the only decent powder I could find mainly due to people thinking it wasn't temp stable. But it was reformulated and is now a stable base powder. As more people found out the more people bought it. Now its both unavailable and expensive comparatively speaking to what it once was.
As for the CFE 223, I bought some as an experiment and it's "OKAY". Not much to write home about.
The Alliant VARMINT powder shows really good velocities and consistency but is about $30 more expensive for a 8lb keg when compared to the shooters world.
For my pistols and other things I just run cheap steel case.
