edju1958
- 2:18 AM
- May 23, 2018
- Western N.Y.
I finally got the long awaited 051AV today.What a basket case! It's missing the choke rod assmbly & the clutch cover & outer bar plate (I knew about the clutch cover & bar plate).Also missing the kill switch.The recoil has the ;ower rear ear broken off where the screw holds it on to the crankcase.Three out of the five AV mounts are shot.I took the plug out to see if it was correct & now it doesn't want to screw back in.The top of the piston looks like it has either rust on it or carbon build up.The decompression valve doesn't work,constantly stuck open.To top it off it doesn't have spark,it looks to have an electronic ignition,but I won't know for sure till I pull the FW.This is going to turn into a major project & money pit.
