RI Chevy
12:59 AM
earth
Is there a range of serial numbers for 461s that are affected?
RI Chevy
12:59 AM
earth
Just curious as to what prompted you to try and remove spark plug on a new saw?
PogoInTheWoods
12:59 AM
Ohio
From what I heard...
See, that's the kind of hearsay stuff that drives me nuts! LOL I've never heard anything at all about bad plug threads on 461s -- from my go-to dealer who sold a truckload of em, or anyone else for that matter. And I've worked on quite a few myself.
I do personally know plenty of *pretty boyes crankin' the piss outta spark plugs and strippin' the threads in all kinds of other saws, though. LOL
spencerdiesel
12:59 AM
Brevard, NC
RI Chevy, I am unfortunately of the category “exceedingly curious” and want to know what everything looks like on the inside. I’m glad I did try to remove the plug, at least I (hopefully) have a chance at warranty if the dealer can’t pull it or it strips on the way out.
spencerdiesel
12:59 AM
Brevard, NC
Does anyone know if Stihl ever remedied this? I’m taking the saw in to my dealer tomorrow.
I did specifically ask for this ms461 because it was NIB. The other two they had were on display. I wonder if that will end up looking funny on my end…..
RI Chevy
12:59 AM
earth
Thank you sir. I was just curious. I hope you make out well. I usually just put the scrench on the plug and give the handle a quick rap to loosen the plug.
Woodslasher
Teh debil
9:59 PM
Commiefornia
https://opeforum.com/threads/buggered-plug-threads.24489/
PogoInTheWoods
12:59 AM
Ohio
So there ya go. It's official.
If there was a T.I. (tech note/bulletin) released, your dealer should certainly know about it. I don't see one in the documentation currently at my disposal. Then again, I didn't see one for the change from the D cylinder to the hemi on the 046s, either. My guess there is one was never released since it wasn't a problem or obvious design change worthy of publication. Faulty cylinders would be a different story altogether -- and a problem Stihl would want dealers to keep quiet about unless seriously pressed by a customer for a warranty claim.
Be honest with your dealer and expect the same in return. But don't accept a faulty cylinder on a brand new saw.
spencerdiesel
12:59 AM
Brevard, NC
Great points thank you. I’ll just be up front (candor I believe the term is) and polite tomorrow, we’ll see.
By the way, how does the exhaust scavenging work on a 461? Is it basically just really short blowdown that pushes exhaust back towards/ into the transfers?
How much is that changed going from stock to a DP muffler cover?
PogoInTheWoods
12:59 AM
Ohio
Pretty much. Changing the muffler cover shouldn't change how that works except making the whole process more efficient as additional intake air is introduced by the increased flow overall. At least that's how I interpret how it would work.
I just rebuilt a 461 with a BarkBox on it for a logger. He bought it from some rich kid firewood guy who just had to have a 500i. 461 was like new. $600 Ran like $hit. Pulled the limiters, re-tuned and it screamed with superb response. No porting involved. Just a lot more air flow.
Here's an illustration for understanding how the 461 is laid out. The PDF offers a bit more info.
spencerdiesel
12:59 AM
Brevard, NC
Thanks for the great read! So the dealer got the plug out, that thing had to be over 40 ft lbs……he’s a big guy and he had to take two tries at it. I’m amazed that the threads are seemingly perfect, and tickled he snugged the plug with finesse.
I noticed this saw has had some amount of run time on it from the factory (unfortunately). Will these “bedding” streaks go away with load and time?
president
9:59 PM
peachland BC Canada
I'm interested in the source of your information..., not doubting you to be a dick. Just curious since my 046 knowledge isn't very broad, though it's basically just a big bore 044.
Such a change would typically be indicated by a specific serial number break point and a corresponding and dated tech note. I can't find one specifically indicating any cylinder design changes you're referring to except maybe the widening of the intake port (and changing the ring locating pin locations to accommodate it) in TI_44_2000. This was early in the 1 48 *** *** serial number range in 2000.
That said, there was a "low compression" configuration (primarily for third world countries and *s-wordty gas) that used an .8mm base gasket. Simply dropping that to the normal .3mm gasket would certainly affect timing to an extent, and obviously compression.
isn;t the high comp metal gasket .5mill?
PogoInTheWoods
12:59 AM
Ohio
So much for the wimpy plug threads in 461 cylinders. And that cylinder doesn't look right to me. Should be nothing but clean cross hatch on the walls and the exhaust port looks to have a very uneven finish. That said, I'd say it's good you took pics now in case there are other issues not immediately obvious.
I'd be keeping my fingers crossed -- or take the saw back again and do some serious comparisons with the other ones the dealer has on hand. The plug should never have been that tight, so..., who knows what else may be going on with it? Better to find out now while the issues are new than after it's been run awhile.
