1:07 PM
southwest FL
I was just told thru eBay.co.uk that it was a restricted item, and that I'll be refunded fully. Probably has to do with the fact they were used engines, with potential oil and fuel still swimming inside.
Kalif. won't allow their citizens to have freedom nor used gas chainsaws to be shipped in. Nope.
eric4
10:07 AM
Northern CA
California covered my root canal today ;) - the cost of two brand new 5100's. Had the freedom to get up from the dental chair and walk to my car without signing a thing 🦅
Then, with the tooth pain gone, I cut some more firewood with the 7900! It's breaking in nicely, keeping an eye on the tune. My pops is already hinting that he may want one now, as a backup for his 620p. Had to break the news, that the 620p would become his backup after trying out the dolmar. hah
Woodslasher
Teh debil
10:07 AM
Commiefornia
You're welcome.
eric4
10:07 AM
Northern CA
The Makita 6421/7900 has been breaking in nicely. Seems like the oiler was pushing enough for my 28" echo bar, but when I pulled the clutch cover, the entire clutch was drowning in bar oil.
Back apart it goes! I'm going to try and re-seal the original rubbers, with a little CA glue. I imagine the seal of the output hose, to the oiler was the failing point.
Gave the oil tank a flush, and backflushed the filter. Are the oil tank vents common points of failure? Could that be a reason this thing would a mess running or not?
Also, tossed in a fresh momentary switch while the oiler is in the parts wash (Husqvarna part no 537419001)20250126_102543.JPG20250126_102611.JPG
7:07 PM
Also, tossed in a fresh momentary switch while the oiler is in the parts wash (Husqvarna part no 537419001)View attachment 448127View attachment 448128
The oil "pressure" line used to be a leakage culprit on elder production units, the current/updated ones shouldn't be a issue.
I would look into the bars oiler hole!
Is it a straight through big round one or one of those "eco friendly" angled needle sized ones?
eric4
10:07 AM
Northern CA
The Echo 7310 bar (first pic) I was running, had an angled oiler port, which was slim. Also looks like I just broke the back side of the bar, somehow. The chain I was running was definitely a couple links too short, maxing out the tensioner. Maybe a little JB weld to fix, and not run that chain again?
I've got a forester 24" in husky mount, that I'll give a go, and see if that makes any difference. Seems to have a larger port, although still angled.
Woodslasher
Teh debil
10:07 AM
Commiefornia
I believe they manufacture the bar that way, I do not believe it is broken.
Mark
Mark is correct, I seem to recall maybe Jacob J saying the old bars were solid right there and had a tendency to crack so manufacturers just started cutting a notch in there as a preventative measure.
eric4
10:07 AM
Northern CA
Oh right on! Glad I didn't screw up the bar. Thank's y'all. I'll open up the oiler ports :)
She's all re-assembled, with freshly sealed oiler hoses. I'll check for leaks in a few hours
Edit: No leaks! Fresh caps - 550xp fuel cap, for the oil tank, and Echo DCS-2500t oil cap (P100004610), for the fuel tank. The echo caps are a stronger feeling, but don't work on lots of saws due to the bulky design.
7:07 PM
ErnieG
1:07 PM
Northeast PA
Anyone hear of a Stihl 460 muffler on a 64-73-7900 saw ?
Guy at saw shop told me today a few of his logger customers did it .
Ernie
eric4
10:07 AM
Northern CA
I was planning on doing it to my 7900, but was convinced by forum members to do a proper muffler mod, and remove the cat, on my OEM Stainless 6421 muffler.
If I was missing a muffler entirely, I'd probably consider the mod
eric4
10:07 AM
Northern CA
Ernie
You can also get nice stainless versions of the 460 muffler as well, thru ebay
Powerstroke Cowboy
11:07 AM
Montana
Ernie
Yup, the only benefit is its easy to do.
Mod the oem one and it will perform as well as any other muffler will and look better doing it!
The best OEM muffler is the aluminized steel one. It's lighter, and easier to work on, plus it doesn't have the emissions components to mess with.
EDIT: The 460 muffler on a dolkita 64xx, 73xx and 79xx saws is a hack job. But, that's just my opinion.
