POULAN The Official Poulan Thread
FergusonTO35
5:01 PM
Boonesborough, KY
It's really sad looking at what Poulan used to be, and what they have been reduced to.
J. Loe
4:01 PM
SE Wisconsin
This is the 1st poulan I’ve had in my hands.
I can’t seem to find much info other than leatherface.
Is this model desirable?
Whadda you say OPE?
A co worker inherited it and I’ve just cleaned it up.
Really really clean under the filth.
Needs a carb to reed gasket and a new duck bill for the gas cap but runs.
Running and clean like this, what do you guys think this is worth?
S Sidwell
5:01 PM
Georgia
Wow, almost like new. Looks to be in pretty good shape, congrats to him. If it was his father or grandfather, there is no price for memories.
Steve, Samsung On5 using Tapatalk
Ganno595
Mixing sarcasm 16:1
4:01 PM
Panama city fl
What's the acceptable left right (in/out) play on the crankshaft of an old countervibe?
S Sidwell
5:01 PM
Georgia
Too much in and out isn't too good either. What model Poulan?
Ganno595
Mixing sarcasm 16:1
4:01 PM
Panama city fl
3400 3700 4000 models. There is no up down just in/out I'd say 1/32" ish. Saw has no leaks tho.
beaglebriar
The Peanut Gallery
5:01 PM
Warren Center, PA
In my experience, If it's real sloppy side to side then it's probably gonna have end play.
S Sidwell
5:01 PM
Georgia
Under 0.015" lateral play, you should be fine.
Ganno595
Mixing sarcasm 16:1
4:01 PM
Panama city fl
Oh its more than that for sure. I've read that roller bearings sometimes had more ... I know the newer ones i have (the ones with less run time) have less play but this one seems to run fine with what I would consider alot. Idk.
S Sidwell
5:01 PM
Georgia
Sounds like the thrust shims may have some wear. If they go, won't be good. Best measure with a dial indicator to get play, 0.015" or less on these 3400-4000. If around 0.020, either shim wear or bearing depth not set correctly.
Ganno595
Mixing sarcasm 16:1
4:01 PM
Panama city fl
Okay another question...if I only swap piston and cylinder from a 3400 to a 4000 will it work as it should? Flywheel...ignition? I would guess it doesnt breathe as good but it should work right?
J. Loe
4:01 PM
SE Wisconsin
Say, would anyone know what check/duck bill valve this 306a cap takes?
S Sidwell
5:01 PM
Georgia
Just guessing but looks like a standard Poulan green duck valve.
S Sidwell
5:01 PM
Georgia
It will swap with No Mods. Just the normal carb tuning. No need to swap anything else.
S Sidwell
5:01 PM
Georgia
My 3400 saw has only the 3700 piston and cylinder. I swapped nothing else. I did unmod the muffler someone hacked up by drilling 6 holes in the front, was too freaking loud.
J. Loe
4:01 PM
SE Wisconsin
Thank you sir.
Much appreciated.
Would you happen to know a good supplier for this?
