FergusonTO35
- 11:20 AM
- Jul 9, 2017
- Boonesborough, KY
It's really sad looking at what Poulan used to be, and what they have been reduced to.
You should worry more about end play more than left to right. Any up and down play is unacceptable.What's the acceptable left right (in/out) play on the crankshaft of an old countervibe?
Run it!3400 3700 4000 models. There is no up down just in/out I'd say 1/32" ish. Saw has no leaks tho.
Run it
Under 0.015" lateral play, you should be fine.
Just guessing but looks like a standard Poulan green duck valve.Say, would anyone know what check/duck bill valve this 306a cap takes?
It will swap with No Mods. Just the normal carb tuning. No need to swap anything else.Okay another question...if I only swap piston and cylinder from a 3400 to a 4000 will it work as it should? Flywheel...ignition? I would guess it doesnt breathe as good but it should work right?
Steve, Samsung On5 using Tapatalk
