POULAN The Official Poulan Thread
Maintenance Chief
2:33 PM
South Carolina
Do you find a lot yours local? The one I just picked up came out of Illinois? I'm just curious about dealer networks in the early 80's?
The poulan chainsaw was extremely popular in the South Eastern US .
The put out alot of Bow saws down here.
Clarkbug
2:33 PM
Northeast
Well, I managed to find enough time to get the PP295 put back together. Carb needed a cleaning (sawdust in the screen), a kit for stiff diaphragms, new AF and new fuel lines. What a pain these are to reassemble! (I am mostly used to Echo/Sthil stuff) Anyway, it was popping off with a squirt of mix down the carb, and ended up running after the H/L screws were turned out maybe 3.5 turns each. Probably the most out I have ever had on a carb. Not sure if that's just the nature of this saw, or if it means I am trying to chase a leak I don't know about.
Managed to get it to idle down and stay running for several minutes. Need to have some more time to try and tune it a little in some wood and see how it does. I will say it seems like it oils like no tomorrow. There was a mess all over everything after I turned it off. Also not sure if its because I didn't cut any wood, so all the oil just kinda pooled and ran around the bar, or if Im actually leaking a lot of it out at the oiler port.
Appreciate the help so far, and any other tips for getting this one dialed in. I have some old beams I am planning to use this bar/chain on, and then planning to put an adjuster on it and get an 18" or 16" setup for it, keep it on hand as my backup/loaner saw.
Well, I spoke too soon.
Im pretty sure I have an air leak. It wouldn't idle down for me yesterday while trying to just make a couple cuts, and then today was trying to drop a few big sumac and it was all over. Kept wanting the L needle out more and more to keep it idling. Which is probably why it got put on the shelf in the first place.
Haven't worked on a clamshell before, and from the IPL it looks like there are two different options for seals. I'll have to tear it all down and then see what I'm dealing with.
B Royals
2:33 PM
Indiana
Does anyone have a line on the FWD isolators for a 5400? Or a suitable replacement? Or is a guy stuck buying them for $30 a piece?
fossil
2:33 PM
Ontario, Canada
No direct replacement but a post back in 2018 on AS which I can't find by a guy that adapted these mounts.
You would have to adapt the mounting screw or theads in the saw in some way.
Husqvarna 501 27 63-0, 501 55 26-02, 501 26 97-04
I haven't tried these but maybe they would work unless you can find some OEM ones.
