The giveaway thread 20/21/22/23/24/25
Woodpecker
Sassy Madam
8:22 AM
@P.M.P. I think you're going to be real happy with these chains. Be sure to set your depth gauges where you like em as I didn't touch those.
Before
After
Good quality oregon chain. You should have 3 very good chains and 1 good chain out of this lot. Merry Christmas bud.
Props to @Steve for sending the low hour chains. Besides being a little dirty I doubt they'd been sharpened even once.
Steve
Excellence!
7:22 AM
Before
After
View attachment 270299 View attachment 270300
Yes, they had never been sharpened. I got them from my dealer new. Free! Just cause I'm a nice guy. I don't run .058 so I bought a .058 24" bar. Also found out I don't use 24" bars! So I sent the bar down the road. 18" and 28" .050 for me.
I was going to clean them off but ran out of time!
Steve
Excellence!
7:22 AM
@Steve
That mini mac 30 popped 170 psi with my Echo compression tester today. As it came from you. My old MM6 only managed 100 and it still runs good. This 30 should feel ported in comparison. :)
Ok, now for the surprise. I completely rebuilt that engine a few tanks ago. New piston, rings, crank seals. It is equiped with the better ZAMA carb instead of the turd walbro. I always thought it ran with lots of power. Just loads up if it idles too long. That is also the quad closed port jug.
Saw Collector
OPE Member
8:22 AM
Here
Well you sneaky son gun. Thanks mang!
P.M.P.
Stiff Member
8:22 AM
Michigan
Before
After
Awesome Brad thank you
@Steve thanks again
Steve
Excellence!
7:22 AM
@Egg Shooter
Here is what I dug up. The complete red one was a runner a few years ago. I could not find any standard crank seals a few years ago when I tuned it up. Mashed some metric seals in it and it didn't work.
Also found a Remington roller nose bar. The roller is seized but it may look good on a small display saw.
And I'll use mini mac parts in place of packing peanuts! :D
PXL_20201205_004209028.jpg PXL_20201205_004220380.jpg PXL_20201205_004225970.jpg
Saw Collector
OPE Member
8:22 AM
Here
countryhog
BTDT
7:22 AM
NW Arkansas
306A parts. Missing piston, cylinder, carb, AF, AF cover, reed valves, electronics (points, condenser), bar and chain. The handle is busted. the good stuff -crank, case, starter, flywheel, starter cover, misc connectors, etc. yours for the ride
Edited
brandonstclair20
8:22 AM
Starkville
Thanks for the bar @JohnnyBlade
