- 4:51 AM
- Dec 28, 2015
- Central Ohio
The Keeper - I built this saw from split cases up with the knowledge I gleaned from AS and SH, I bought parts mostly from Ebay, all OEM and ended up with a 046D cylinder for it that I cleaned up using the "randy" method.
I ran this saw for more than a year with the wrong oil seals because some body told me the bearings AND oil seals for the 044 and 046 matched. In fact only the bearings match the seals are visually close unless you have both in hand.
When it finally developed a leak, my climber was running it and shut her down mid cut and told me " this saw is the leak Dave, no more run, you fix" and put it in the back of the truck after taking off the bar and chain. I got lucky.
This past year I picked up a ported 046D jug from Miller Mod Saws that I put on my baby. Everything inside still looked great and the 046D that I had installed initially is now on Mike (Glock37)'s next project saw.
It picked up about 30 PSI and is an angry mutha in the wood. Carl told me it would like an 8 tooth and he didn't lie
This badboy wears Metals406 Dawgz and enjoys mimosas on the beach.
