The best Chainsaw soap and what ratio ?
3:02 AM
I like this stuff works real good. Screenshot_2017-07-07-00-44-49.png Of course I cheat and use the parts washer at work and wipe it all down with industrial alcohol
Homemade
4:02 AM
Wisconsin
This is what I switched to and love it. I spray on and let it soak for 2-3 minutes. Then wipe off with a rag. Works about as good as brake clean and compressed air, but I don't worry about fading out plastic or wiping away stickers. The brake clean also burns like hell when you spray it into a cut or gets behind my wedding ring.
Dolmar Junkie
Not interested in rehab, just more Saws...
3:02 AM
N.Central Arkansas
Honda GX200 with a Cat Triplex pump pushin about 3200psi @ 3.2
Thanks, good info, as I have found that the 3500psi I was using tended to disassemble them prematurely. I guess it's a numbers game, was never too good at cyphering...
Loanstar
When I grow up I want to be a "they"
3:02 AM
east texas
I like the ratio of $1.50 at the car wash, then I go home and oil/grease moving parts. Sharpen/adjust the chain and she's ready to go for the next outing.
isaaccarlson
3:02 AM
Colfax, WI
I use super concentrated dawn, the purple stuff. Takes the trime right off. Just a squirt in the sink with 160* water and let the parts soak for a bit, then brush clean. Rinse and repeat if needed. Every saw I have done this with has looked like new.
Terry Syd
8:02 PM
Comboyne, NSW Australia
Old habits die hard. Left over from my dirt biking days, I just use pre-mix. It washes things up and will penetrate into cracks and threads - leaving a bit of oil behind for long term protection.
I hate it when a bearing or thread gets corroded from water cleaning and pressure washing is the worse for pushing water into those small places.
shadco
Ban Hammer Custodian
4:02 AM
City of Oaks, NC
Ok when i take a sticker off my saw to replace with a fresh one ,it leaves the glue behind ,it just smears ,what kind of soap to get that off ? Or will a razor blade scrape it off ?
Late reply but, lighter fluid.
PA Dan
4:02 AM
White Oak PA
WD40 or Rem oil makes easy work of it!
thedude74
Bonafide & Stuff !!!
2:02 AM
Alaska
Snow and diesel! Snow for mild abrasive action. Diesel really is one of the best solvents. Make muh saw smell like muh tractor!
