- 12:42 AM
- Dec 3, 2015
- Banner Springs Tennessee
So it wouldn't do much for the Dolmar 7900 you ported a muffler modded for me?
Sir no sir. 93 is as much as I'd recommend.
Oxygenated fuel has benifits, but does it out weigh having more octane?
Old✓I've never tried anything like that. I'm old, boring, and have bad gas.
Actually given the fact the fuel in question is oxygenated you will make more power with it. Useful for racing, but I cant see it for everday use given the low compression ratios of chainsaws.There's no benefit to running high octane like that.
I've never had any problems running cheap pump fuel with ethanol in it in chainsaws with it melting crap like fuel lines carb diagrams or anything like that.
Now the two things that I myself have had problems with running the crap pump gas here is the saws are down on power gutless and on a hot summers day hard starting.
Running it in my two stroke mower in summer after say 20-30min use and after shutting it down I'd have to let it cool for 20-30 min before the fuel would cool and actually run again through the clear fuel line I put on to help diagnose what was going on.
Anyways as an experiment I tried avgas easy for me to get there are 44's of it at at work.
It's then I realized how down on power they where and yes I know avgas is the wrong fuel for low compression Two Strokes but there was a massive pick up in power in all my T2 gear one saw in particular felt in hand like it had double the power. I'm not saying it's a race gas and gives ported saw power I'm talking back to stated stock power that's how down on power they where.
Now I don't go out of my way to get avgas it was an experiment that showed me just how bad the pump has has gotten here.
The pick up in power I put down to avgas is closer to a real fuel chainsaws used to run on then the crap pump fuel they sell today.
If your saws don't seem to run like they used to years ago get your hands on something closer to what real fuel used to be even if its high octain and see the difference yourself I was shocked myself just how crap the fuel they pass off as fuel to us is today.
I can only imagine how good they would run running the correct octain fuel like the good old Super we used to have here years ago back when fuel was fuel.
This is just my experience with fuel from my Indian servo I get crap pump gas from.
Ethanol isnt as big of a deal with four cycle engines as they dont have raw fuel sitting in their crank cases like a two stroke does. Since ethanol attracts moisture it's not easy to figure out where corrosion is an issue. Using ester based oils only makes this worse.I have 6 five gallon cans I usually fill with regular and another for E free. Like you say the Ferris and LoBoy don't care if the gas is 6 mo ths old. The funniest thing is the old motor home in the barn has been setting for untouched for almost 3 years. Regular gas with no stabilizer went to start it figuring the entire fuel system trashed. It started right up. '89 P30 chassis with a carbureted 454. Never would have thought that.
