Rodney McCarty
New OPE Member
- 9:38 AM
- Dec 23, 2015
- cave city arkansas
what is a better clutch cover the rim sprocket or the spur cover? and which one lasts longer?
To be clear I accidently double posted the same thing. Don't look for a double post rim.Double post
A rim sprocket is probably technically better but for a typical user it makes very little difference as a spur sprocket is cheaper and will last a long time. I have saws with both and performance wise there is no difference. A spur sprocket is actually a little easier to fit the chain to. The rim sprocket is handy if you want to change sprocket tooth count or chain pitch as just the rim has to be changed. These are about $5.
Howdy. Thought I'd stop over here and see what's going on.Hello Sir.![]()
