Randy, you have been all through these things; there simply isn't any TPS, temp sensor, map sensor etc. Right?Yeah......I tried that too. lol
Max rpm in the cut requires a proper tune. Too lean and you loose power, then rpm drop.If it were looking for max rpm it would run lean and burn up.
If tune changes with temperature wouldn't monitoring rpm and temperature be the same thing in a round about way.
I believe M-Tronic limits max RPMs with timing changes. Otherwise, the saw would blow itself up. (I don't remember where I saw that, but I don't think they do it with fuel).
Also Dan, when you cut the key I believe you change the range in which it can operate. For example, maybe it can move timing 10 degrees, from 5 to 15. You cut the key, now it is 10 to 20. I don't think the range it can adjust is unlimited.
[emoji41]I will politely disagree. If it can only advance to a certain limit, and you change that limit, along with mods that call for more timing, I believe it will respond.
Well, I do not definitely know the answer, but even if the stock timing range is conservative, a feedback system would still allow it to change on a stock saw. It is also possible that you cut the key to allow an additional 6 degrees of advance, but based on feedback it only provides 3 addl degrees??? I guess if we over advance one, we would know.
