Carhartt
- 9:59 AM
- Aug 18, 2016
- Central Pa
I wouldn’t want to use anything else now that I have mine set up the way I do.
And we have one at work that is just bolted to a wall no vacuum and no additional lights and for some reason I don’t enjoy running it
CBN wheels are must for me
Long chain set up
Not the most professional look but works
I just watched your video on the Tube the other day. Cool setup indeed.
Long chain set up
Thats about 750,00 US dollarswe have 220v different but different 3 pin plug, should have been clearer about importing a tecomex grinder but I can buy a USG here for a little over 500 euro
I've used a few over the years.
Started out with the one from Northern tool. Then a Speed Sharp (Tecomec Hydraulic) which is now raker duty only.
Have a little Jolly I bought used but not used myself yet.
Currently running a Stihl USG. I like the USG the best. Great adjustment features.
40 deg tilt, 28 deg angle on the vise, and 15 deg offset.
I run the Stihl wheels. They do a nice job for me.
~Edit~ All of my grinders were purchased prewoned except the Northern Tool. I still paid quite a bit for the USG used.
Good logic, I,ll give it a go!If I remember correctly, I believe it's the angle that matched a chain I though cut extremely well.
It could be the angle for the Husqvarna X-cut chain, or some old Homlite semi-chisel I bought a bunch of years ago.
It's been so long since I set that mark, I really can't remember which chain it came from.
T1!The Stihl wheel seems great imo also. What I like best about the USG is you can set it and both cutters (L and R) will have the same geometry and length. My Oregon would not even be close.
Since you have both, would you translate the angles from one to the other? Please and thanks.I've used a few over the years.
