HELP! STIHL Pressure/Vacuum tester rebuild
Stihl Wrenching
2:30 PM
Coushatta Louisiana
I work on Stihl saws almost every day. I have used this forum as research for years when I need ideas and have really enjoyed the exchange of knowledge. I use my Stihl P/V tool all the time and have used it for many years. I couldn't do without it. Yesterday, before checking out a saw, I put my finger over the end of the tool and noticed that it would hold on pressure but not on vac. I am used to looking up Stihl parts and I can't find a rebuild kit for the tool. I checked with Stihl and they don't show a rebuild kit. I can't find schematics. I need help finding a kit, schematic or a list of all the o-ring sizes. Thanks, John
Loony661
462’s 4-LIFE
2:30 PM
Winona County, MN
I know those were outsourced from another German company for Stihl. If you can find the maker, you’ll have a better chance at finding the parts.
Loony661
462’s 4-LIFE
2:30 PM
Winona County, MN
Thanks, you are right. At the bottom of the gauge it says LTR which is Leitenberger from Germany. I'm still looking.
I couldn’t remember the name, and couldn’t look for you as I don’t have one yet. I just remember in my search for one a while back.
Stihl Wrenching
2:30 PM
Coushatta Louisiana
I looked through all of Leitenberger's tools and found it as item number: 060107 model HV 90. But still can't find rebuild/repair info. I'll check with Dougan next. Thanks.
Djj450
Active OPE Member
7:30 AM
Thanks! Just saw this reply. I still needed this.
Hopefully you can find something as that is from the manufacturers old catalogue, the new one doesn't list any parts for rebuilding. I emailed the manufacturer asking about rebuild and they said they don't sell parts if you need service to send the tester to them and they can quote you on cost of repair. For the cost of the item you would think you could buy parts to service it.
stihl #1
3:30 PM
Florida
I wrote this procedure and sourced the parts back in 2017 when I worked at STIHL. I don't know if WEZAG still supplies parts or not so just have to call them and see. The 2 check valves get messed up from sucking soapy water or other chemicals up, so I always pull a little WD40 in from time to time which seems to help.
Stihl Wrenching
2:30 PM
Coushatta Louisiana
This was a good lead and I appreciate your looking it up. Wezag is not carrying the parts anymore but it at least gave me part numbers that I can call and give to Virginia Beach. Maybe someone knows.
stihl #1
3:30 PM
Florida
Back when I was at STIHL Inc., STIHL Germany did not make the parts available so that is why I searched and found out WEZAG was selling them, so I doubt Virginia Beach will have them. However, I am going back there next week for the 50th Anniversary celebration so I will ask around and let you know what I find out.
backhoelover
I like tools
3:30 PM
lincolnton nc
have any of these for the platinum class? i have all the golds
S&S_Work_Saws
#1 Ranked Riff-Raff
2:30 PM
Salem, Missouri
Finding anything for this one is probably impossible at this point. I'd like to find a set of instructions
backhoelover
I like tools
3:30 PM
lincolnton nc
I do know that the blue tool is vac only, you have several block offs. the dial indicator is for setting timing on the old points saws, just got to make sure you have the tool to attach the dial indicator to the saw. if you looked into some 056/076, 028wood boss etc you will see some of the tools in the kit being used in the manuals
