Stihl MS660 nasty vibration
kjudd
7:47 AM
Vermont
A busted spring
A cracked shoe
The oiler arm not being in the slot on the drum
Etc ......
All cause vibrations
The saw ran smooth before the cross top end. I took a huztl big bore top end off to put the cross on. Because my base gasket deleted Huztl 660 would out mill the big bore saw. So figured I would try the cross top end on it to see if the 2 would cut roughly the same.
7:47 AM
Make sure the flywheel was not hitting the cylinder, they usually (the Cross cylinder) have to be filed.
Also, I'm not sure why, but one of mine needed spacers on the lower muffler bolts, but not doing that should not cause vibration.
Wonkydonkey
Plastic member
12:47 PM
Sussex, UK.
This was what I was ref: to. If it works fine with the big bore hutzel, now it vibes like a sob.. With the cross. Put it back to how it was.. Then, it's a process of elimination as to the vibes.
But as with all things China-style, some work good and some are crap.
Btw. A few have said (many builders) std cylinders work better than a big bore kits, as you have better case compression. Also the cross is/should be better than a std hutzel cylinder.?
kjudd
7:47 AM
Vermont
I'm hoping to fire it up in the next few days to see if the bearing swap fixed the problem. Then I will go from there.
The huztl saw is a base gasket delete with minor port job on it. Basically a smoothing of transitions and widening of the ports. and gasket matching the muffler with a muffler mod.
kjudd
7:47 AM
Vermont
Did you take a real good look at the crank while you were in there?
Yes. No marks on either crank or piston. Also made sure to pay very close attention at bdc for any binding/hitting feel.
7:47 AM
The Cross cylinders will also usually out perform most OEM cylinders unless they have been ported.
kjudd
7:47 AM
Vermont
I swapped out the wrist pin bearing. That appears to be the problem. The saw is alot smoother now. Thank you everyone for the suggestions. I still need to check the clutch.
kjudd
7:47 AM
Vermont
Here is the wrist pin bearing I took out.
r7000
7:47 AM
CT
I just finished putting a cross top end on my 660...
did you ever figure out the cause?
by "top end" does that mean just a cylinder? or cylinder and also new piston+rings?
7:47 AM
Often AM pistons and pins are heavier than OEM, and will result in increased vibration, ditto all Big Bore Kits.
Also, if your AM piston pin begins to fail, you will also notice increased vibration. Don't ask how I know, but for $10 I now use OEM wrist pin bearings.
Luckily, I felt it, and tore it down before damage was done.
kjudd
7:47 AM
Vermont
I changed the bearing the piston rides on. Smoothed it right out.
Yes I put a the whole cross top end in ( ie the piston, cylinder, rings. ) with no base gasket.
