Nothing wrong with decomp valves. I wish all saws had them.
I use them for every start. Even though they really aren’t needed on saws (ported) under 70cc IMHO, I find nothing wrong with an easier start with less wear and tear on the starting system.
My own ported MS261 will get ripped from my hand if I don’t use the decomp and don’t start it like I mean it, even warm. If I press the decomp it’s a quick 2 finger start. Little saws have 2 issues with starting if high compression. One is the perception that it’s so small it’s a joke to start, the other is lack of weight for the inertia of a drop start.
Then there is the myth that they will leak and lean a saw out to the point where it fails. If someone can explain this to me I am all ears. At what point exactly with the end of a decomp valve in a cylinder become under negative pressure/vacuum in a running 2T engine?
Even though I can start a saw without a decomp it doesn’t mean I want to.
