Stihl KM100 Carb setting from factory
Tom hadlow
Active OPE Member
11:37 PM
Uk
Hi I am currently working on a stihl km 100 or 100r and have just finished rebuilding the carb i don’t know what the factory settings for this carb is and the problem I am having is they will idle ok but as soon as you give it any throttle they will die any help would be great thanks tom
mgr1
12:37 AM
Belgium
Limiter caps removed?
H 2 turns out
L 3 turns out
Those are factory settings without limiter caps.
Tom hadlow
Active OPE Member
11:37 PM
Uk
H 2 turns out
L 3 turns out
Hi mate I have just done that I am still having problems with I die in on throttle I have found a small air leak on the rocker cover gasket and have put one on order do you think this will be causing the problem thanks Tom
mgr1
12:37 AM
Belgium
Could be the problem. I dont know anything of those 4 strokes. :oops:
DND 9000
12:37 AM
Germany
Hi mate the carb number for is 4180 120 0608 and the numbering on the carb is
C1Q-S174 thanks Tom
Thank you for the information.
The "4180 120 0608" number is the C1Q-S131 carburetor, not the C1Q-S174 (4180 120 0611). Basic setting for these 2 is a little bit different.
If you have a C1Q-S174, basic setting is:
L: 1 1/2
H: 3 1/2
