Stihl heated handles
jmester
10:39 AM
VIRGINIA
Has anyone found a good way to reattach the heating element in the rear handle.
It has a stickie backing when new.
I feel once pulled off. Its not going to stick any more.
ammoaddict
10:39 AM
Granite Falls, NC
Maybe double sided tape?
Sent from my moto g(7) power using Tapatalk
jmester
10:39 AM
VIRGINIA
I thought about that. But the service manual wants a tight bond to the rear handle. As the element can overheat and burn out Screenshot_20211225-102225.png
ManiacalMark
10:39 AM
PA
I don’t think spray adhesive would be strong enough
jmester
10:39 AM
VIRGINIA
Your probably right. There was a thread on one of the forums a few years back. That a guy was reattaching the heating element. With success. I remember reading it, but I sure cant find it now
Homemade
10:39 AM
Wisconsin
A thin layer of clear silicone calk. We use it all the time to attach hard plastic labels on outside electrical boxes. It sticks really good and is flexible to withstand vibration and heat cycling.
jmester
10:39 AM
VIRGINIA
Do you have any specific recommendations?
Glock37
10:39 AM
Monroeville Pa
Get a new one from stihl
All the same
Not much from dealer
Basher
11:39 AM
Canada
Silicone often gets a bad rep for not sticking stuff, the thing is that silicone really needs the surfaces to be overly clean of all contamination, one needs to work diligently to get the surfaces super clean and dry before applying the product. That does not mean one can swipe a finger or thumb over the part and that be good enough, just remember squeaky clean and dry.
Homemade
10:39 AM
Wisconsin
jmester
10:39 AM
VIRGINIA
Cool already have some of that in stock. Thanks
4:39 PM
Hey everyone!
I have the part number 1128 434 5000 for the 064/066/660 rear handle heating foil.
Can You Stihl-heads check whether this is the current part number and if there is a newer one please post it!
Thank You very much! :beer-toast1:
Wonkydonkey
Plastic member
3:39 PM
Sussex, UK.
My 044 was loose. So I used a bit of foam to hold it in place. Also one of the wires came off while I was faffing around. I had to solder it back on.
I didn’t want to pay the silly price they charge here. I have to pay the vat. So it’s. £34.64
