SOLD Stihl Cylinders, Pistons, Crankcases, Plastics, ms362 parts & more.
DND 9000
4:00 AM
Germany
A good observation, sorry if there's been any confusion with this stuff folks. I forgot how many variants of these parts are out there. To clarify, these parts came off a 2012 standard ms362 with serial 289894395. It was non m-tronic with the adjustable carb. I will include part numbers with the pics and prices. Also I highly encourage folks to ask questions if ya got em. I want to make sure people are getting what they need.
Sent from my SM-N970U using Tapatalk
Thanks for posting this information. Now it is clear. You offer parts for a previous version saw, which means:
Carburetor bracket is: 1140 120 0901
Intake manifold is: 1140 140 2500
Air guide shroud is: 1140 080 0900
These parts have to be used for MS 362 saws before the slanted fin cylinder was introduced. Also the air guide shroud is a version for the older flat air filter not the new round HD2 type.
Sagebrush33
10:00 PM
Upstater
Subbed .....I'm a saw hoe so I'm sure there will be something sparking my interest at some point.
Sagebrush33
10:00 PM
Upstater
To
BangBang thank you!
Could I get some input from folks on this piston? It's an old KS piston for an 064. Has some wear on top and some dings from the the saw ingesting something. Skirts seem good though, there's a scuff on the exhaust side but I can't catch anything with my fingernail. Ring grooves and landing pins are good. Piston to Cylinder wall clearance is .003 and that was tested on a very used 064 cylinder. Stihl logo is barely visible on top and I can see the letters BE showing. Is it still usable or should I toss it in the recycle bin?
To me, that's a usable piston. That's as far as the skirts and ring lands look. The top has "hot spots." Could lead to detonation?
My knowledge is coming from the 4-stroke world.
Could the top be filled with weld and still be worthy? Shaped smooth afterwards of course.
northwest saws
10:00 PM
North Idaho
Some carbs to add. One is a new old stock Bing 49 for the 064. Two Walbro carbs for 064/066 are good but probably need a kit or cleaning. 044 walbro carb is in good used shape. 044 Zama carb is also in good shape and ready to go, passed pressure/leakage test. Chinese carb is for 1128 series saws. All the ms250 carbs and ms170 carb will need kits. One of the ms250 carbs has the fixed high jet.
064 Carbs
Bing 49 Nos. $65
Walbro WJ-6A Sold
Walbro WJ-10A Sold
044 & MS440 carbs
Walbro HD-17A Sold
Chinese no name New. $10
Zama C3M-S5G. Sold
MS250
Walbro WT-283B. $10
Walbro WT-215. $10
Zama C1Q-S75B. $10
MS170
Zama C1Q-S57E. $5
northwest saws
10:00 PM
North Idaho
044 part out. All of it is sold. Thanks everyone!
Piston(12mm) & Cylinder Set Sold
Complete Starter Sold
Brake handle Sold
Oil pump Sold
Flywheel Sold
Coil Sold
Coil(without spring+boot) Sold
Top cover Sold
Fuel tank Sold
Spike set Sold
Clutch w/ washer Sold
Clutch Drum w/ small parts Sold
Worm gear Sold
Brake band Sold
Crank 12mm Sold
Muffler Sold
Brake tension spring Sold
jacob j.
Only the weird
7:00 PM
Coastal Oregon
I think I can go for that thar tank...
BangBang77
9:00 PM
Oklahoma
I will take the Mahle piston & cylinder.
Edit - I will pass as I am looking for a 10mm piston. My bad.
Scotty Overkill
Serial Tree Killer
10:00 PM
central PA
Impressive collection of QUALITY 044/440 parts here!
Is the 064 carcass w/wrapper handle still available?
LB350
New OPE Member
10:00 PM
Pennsylvania
Hello everyone I'm a new member here
I'm interested in the ms362 case if it is still available. Northwest you can pm me
Donwon2525
10:00 PM
Lansing Mi
I’m looking for a 064 oil pump if anyone has one?
badmowfo
Active OPE Member
10:00 PM
Pennsylvania
I need a 064 flywheel 1122 400 1201 , if you have or know someone that does.
