Stihl 361 Leaky Carb
16TAF
6:25 AM
VA
I got a new intake boot and impulse line, I’ll get a new tank vent tomorrow. That’s about all I know to do with it. I’m guessing where the carburetor meets the intake boot isn’t making a good seal since two different carburetors leaked from the impulse hole.
hacskaroly
2100 Fanclub Member
3:25 AM
Northern Idaho, Ehh
This is more of a general question for everyone, but shouldn't it be an issue for fuel to be coming out of the impulse hole - shouldn't this just be a pressure/air passage to cause the pump diaphragm to go up/down? If this is the case, I am wondering how the fuel is getting around the gasket/diaphragm. I understand that the pressure/air going through the impulse may have atomized fuel, but should not be enough to be leaking out.
EFSM
5:25 AM
Extreme southern IL
It held at .5 for about 10 minutes. It’s holding pressure but pushing fuel out of the impulse hole.
This is very good. Are you using a black rubber pump diaphragm or a tan Mylar one?
The boot seal has nothing to do with the “impulse hole leak.” But it sounds like any leakage the carburetor has is so negligible as to have no effect. I have never pressure tested a carburetor for nearly 10 minutes, or even a minute. I expect that the Mylar diaphragm would be more likely to allow some air through it. Hey, rubber tires do over time and they are a lot thicker than a diaphragm.
16TAF
6:25 AM
VA
The OEM carburetor has the tan Mylar and the aftermarket carburetor has a black plastic pump diaphragm. I wouldn’t worry about it but it is keeping everything under the cover wet with fuel.
EFSM
5:25 AM
Extreme southern IL
Are you saying that it leaks from .5 bar to nothing in 10 minutes? Or that it takes 10 minutes to show leakage? I think I’m misunderstanding you.
16TAF
6:25 AM
VA
I had the carburetor pressurized for about 10 minutes and it didn’t leak down. I set it down and started something else and didn’t realize it had been so long.
16TAF
6:25 AM
VA
Me either. If I can’t figure it out I’ll send it on its way.
5:25 AM
An internal leaking gasket will do such a thing, basically it's a short circuit of sorts.
