SOLD Stihl .325 x .063 x 67dl 16”Square Ground
Trader history (2)
Duane(Pa)
It's the chain...
12:50 PM
Centre County
F9900FEF-7EEB-4D8D-95C7-B3DBD712A08C.jpeg 9A46A5B0-5FCC-4688-BA67-FED2FA09F3C0.jpeg I am trying to consolidate my chains (again) Two square ground chains from Icepick69. Used for a few cuts. Still good and sharp. $15 each plus shipping.
RockiesRider
10:50 AM
CO.
75. Works with 8 and 9 pin rims. If I recall it will also work with 7. I can check and report back.
I'd appreciate it, I have my ported 036 running. 325 and I think a square grind chain would compliment it nicely.
Ryan Browne
11:50 AM
Wisconsin
Is that 036 still using the smaller needle bearing and drum setup? If so, you could use this opportunity to swap to the larger needle bearing, which is a good idea. Then it will need a 9 pin on it and this chain will fit without sharpening.
RockiesRider
10:50 AM
CO.
With out sharpening? Is my current clutch drum is pn 1125 160 2900a
RockiesRider
10:50 AM
CO.
Needle bearing is .493
Ryan Browne
11:50 AM
Wisconsin
I don't know the specific size, though 12 and 15mm ring a bell. If your 036 can fit a 7 pin 325 sprocket, it should get upgraded. There's a kit available. The needle bearing was prone to going out and sometimes damaging other parts, hence the change in later models and kit for older saws. If you do a search on here it should pop up. If you can't find it, reply here and I'll see if I can dig it up.
