Vintage Engine Repairs
- 10:48 AM
- Aug 15, 2019
- australia
Hi, another project and hopefully challenges to overcome.
This time a stihl 08s again for the owner of my local Stihl shop.
It’s having a full overhaul as well as some fabrication of a new handle brace pocket (notorious for mag rot and this is no different). More on that later.
I did the tear down today and there are 3 notable mentions so far.
First, removing the clutch side key.
Someone was in this saw before me and had a good go at removing it unsuccessfully, it was well and truly stuck and beaten up.
I initially tried getting a pick inbeteeen the flywheel and key to no avail. Then I tried carefully with a screwdriver with no luck.
Then I tried some penetrant and the above methods with no success.
Then I tried heat and penetrant and the above being very aware not to go above 150c checking with an IRT as it would start to affect the metal temper. Nothing..
Then I decided to drill a 4mm hole in the key and tap the threads and pull it out. Knowing the key is soft I did question if the threads would just rip out. Therefore if that failed my backup was to then tap to a 4mm thread repair. If that failed I’d move up to 5 and so on.
Anyway, drilled, tapped and used two hammers and after a few knocks of the hammers the key eventually came out.
