- 11:41 AM
- Jun 21, 2020
- Oil Country
Could this be an ignition issue as in weak spark?
+1..... and dumb question for the OP.... did ya throw a new plug on it? Did you check to see if it has good spark cold and hot?Could this be an ignition issue as in weak spark?
Well, that won’t make the saw flood. But it could hang a ring if backwards. Pull your muffler and make sure you can’t see the ring end pins.Sitting here thinking of the saw and my build, of course the GF thinks I am thinking of other girls, anyway, I was thinking, there was no arrow on the piston, so I put forward the engraved numbers, is it possible the piston is backwards??
Good for you !Thought I should update, it was a sheared flywheel key.
That would probably explain why you could even pull it over when it was flooded, probably just spinning the flywheel a little every time.Thought I should update, it was a sheared flywheel key.
