Fruecrue
certified hand catcher
- 12:49 AM
- Jan 4, 2017
- Alden NY
Late model 064.
Mild porting, ports widened at piston only, port timing not changed other than BGD.
Muffler is gutted and 2nd port added.
New Meteor piston with caber rings.
Base gasket delete with squish cut to 0.025”.
Compression was about 185 on assembly.
Timing is still stock, seems aggressive enough but I can advance and re-tune if buyer requests.
West coast clutch cover (small chip at rear).
Dual dogs.
Roller chain catcher.
WJ-48 carb.
Runs, idles, oils as it should.
Piston pic is after 3 tanks on the new slug.
I ran the saw this morning stumping some big ash with an 8 pin and it didn’t leave me wanting more, it’ll really pull you in or push you away.
Please notice the bottom of the case in the pic. This truly is a low hour saw. Bottom end is all original. Piston was replaced due to carbon streaking, saw ran quite well with original piston.
Only selling to fund a couple other projects including another 064 build.
Asking $625 plus shipping, please let me know if I’m off base on price but these aren’t coming up for sale in great condition very often.
Dual dogs.
WJ-48 carb.
