Stihl 064 help
RedFir Down
10:24 AM
Idaho
I just called the owner (a good friend) and told him he bought an over priced parts saw. :(
12:24 PM
All of em that I've ran, 066/064 are that way
I've only had 4 in the shop with the older style L shaped lever. 2 were brand new and worked. The 2 that were used acted just like yours. Guessing they didn' work correctly for very long
RedFir Down
10:24 AM
Idaho
I just heard back and he wants it repaired/rebuild.
Before I order a set of gaskets can some one tell me if this a 064 or 066? The serial number is 122059068
I measure the bore through the exhaust and it measures 54mm so I'm assuming it's a 066?
Thanks again.
Moparmyway
Its just a saw
12:24 PM
In a meeting
Cracker Boy
Fl cracker
12:24 PM
Florida
If you use 066 660 muffler you wont most likely need the spacer. I have 2 064s and an early 066 neither needed spacer with the later 660 muffler Easiest way to tell if its 064 04 066 is the flywheel and oiler. The 064 flywheel is about an in. wide and has external oil line same as 036 oil line kit actually and suck to install And 066 has a flywheel about 2 in thick and oiler screws to case with no external oil line. Also 064 066 gasket set is same part number comes with 3 crank seals depending if saw has small diameter crank or large diameter . 660 seal kit is diff seal kit part number all together. All 064. 52 mn cylinders were thin base as well. Were as 066 660 were thick base in most cases and were mahle although some 066 specialy early red lights did have a thin base cylinder 54 mm. 064 and 066 share the same fuel tank as well. 660 fuel tank is diff due to 660 being a bigger crankcase.
RedFir Down
10:24 AM
Idaho
Thank you. I also just found this thread. It looks like it is a late 064 1988 crankcase.
http://opeforum.com/threads/finally-decided-to-pull-it-out-and-measure-it.2136/
Good to know, thanks.
Does any one know if the early to late control levers interchange?
I'm going to replace this one and not sure they still make the early style.
RedFir Down
10:24 AM
Idaho
Here is the case.
Sent from my VS870 4G using Tapatalk
Cracker Boy
Fl cracker
12:24 PM
Florida
If its late model case should also have w screw holes real close together by pin boss on flywheel side if so and it dont allready have you can put standard unlimited coil same as 026 036 044 1300 and a 1203 1204 or a 1204 unlimited coil and get away from them old dog leg limited coils that were known for failure that are nla a 1201 flywheel will work too.
Cracker Boy
Fl cracker
12:24 PM
Florida
RedFir Down
10:24 AM
Idaho
This really going to show my 1122 ignorance but will a 066 piston and cylinder bolt on to a Late 064 case?
jacob j.
Only the weird
9:24 AM
Coastal Oregon
It's not a bolt-up affair. The 064 case (in the U.S.) was never converted to accept the 066 top end from the factory. Apparently there were 064s sold in Canada that were said to have had the same cylinder spacing as 066s but the one guy that posted that never posted any pictures or other documentation, so I'm doubtful.
The gasket set you need is 1122 007 1051. It's the only gasket set that fits the 064 and metal flywheel 066 cases. Just the single crankcase gasket is 1122 029 0500.
RedFir Down
10:24 AM
Idaho
I pulled the cylinder late last night and it is indeed a 064, 52mm. My fault thinking it was a 066 for a bit. I screwed up the pop sickle stick trick.
I got the gasket set number on my list, thank you.
Cross Performance has a 066 top end with the 064 bolt pattern.
Good to know. I pulled the cylinder and don't like how the plating looks, I'll post a picture in a bit. This saw needs junked!!:BangHead::bash::2guns:
That's the one you helped design right Randy?
I skimmed through a few threads last night and noticed mixed reviews.
How does the cylinder look out of the box, does it need any work?
Have they been holding up? I noticed some were having premature plating issues.
RedFir Down
10:24 AM
Idaho
Here is the cylinder, like I said I don't like the looks of the plating.
What do you guys think? @Mastermind
