- 8:11 PM
- Feb 5, 2016
- Glenside Pa.
I'm putting together an 046 and am in need of a tank. It doesn't need to be pretty, just functional.
Thanks
Jeff
Thanks
Jeff
that’s a 044 tank by the orange plastic filter mountI’ve got one. Looking to sell everything in the photos. Have more parts also.
Thanks, Howard View attachment 177730View attachment 177731View attachment 177732View attachment 177733View attachment 177735
046 is about 3/8 wider and also the carb mount studs are about a half inch or more longer on the 046I was under the assumption that it would fit both?
Well *s-word. I stand corrected. Learn something new every day. I’m just gonna stick with Huskies!046 is about 3/8 wider and also the carb mount studs are about a half inch or more longer on the 046
don’t be sad those are hard to come byWell *s-word. I stand corrected. Learn something new every day.
also by the air filter mount that says it’s a early model and probably a zama carb hiding under there with no snorkelI’ve got one. Looking to sell everything in the photos. Have more parts also.
The vultures are circling.......Well *s-word. I stand corrected. Learn something new every day. I’m just gonna stick with Huskies!
I agree. That’s an early 044 fuel tank. Still has the old style impulse line that was used on the 10mm saws, low profile fuel cap and no spot for the metal chain guard on the corner of the tank.also by the air filter mount that says it’s a early model and probably a zama carb hiding under there with no snorkel
046 has the v stack also, right?I agree. That’s an early 044 fuel tank. Still has the old style impulse line that was used on the 10mm saws, low profile fuel cap and no spot for the metal chain guard on the corner of the tank.
Yup, you are correct.046 has the v stack also, right?
