- 2:20 AM
- Dec 29, 2015
- Strong Island NY
If you're gonna port them, it shouldn't matter. But....
My understanding is that the 10mm jugs have a narrower intake port to correspond to the narrower ring pin placement of the 10mm piston. So if you get a 12mm jug, the intake width may be in the pins and be a no go. I'm not sure if after assembly, the ends may still be above the port at BDC. You may need some finageling during assembly.
The meteor 10mm piston MAY have wider pin spacing than OEM. In fact, I'm pretty sure it does. It shares a lot with the 12mm casting. Actually too much-the pin bosses are spaced for the 12mm rod and too far apart to fully locate the 10mm bearing in the small end of the rod. That's why many won't use a meteor on the 10mm 044. I have one in mine and it runs just fine though.
