- 11:01 PM
- Mar 13, 2023
- Maryland, USA
Is he on here?That's Bryce out in St Marys Washington .Has parts measured in tonnage .
I have no ideaIs he on here?
Define, can of soup...Two more variations of the model tags .Left is a German made that spent twenty years of hard service for a tree company.I had rebuilt that thing twice since .It's came out of retirement twice since as well .To the right made in Brazil .That one I added a can of soup ,it's one of my "go to " saws
Which means in Ohio red neck slang the engine has been modified.Define, can of soup...![]()
For right now, because it's in hand, this is a hiway top end...It's a matter of opinion .Some prefer to keep the exhaust long,101 or so .Some,myself raise it up a tad for RPM .If I recall my modified mag is around 96-98 opening and dead sticks at 14,500 .Runs an 8 tooth rim even on a 32" bar .What ever floats your boat I guess .Keep in mind both the uppers and lower transfer ports were reworked and it's got a raised dome piston and pumps betwwen 180-185 static .
Keep in mind an 038 AV has a hemi domed piston and an offset chamber which might act slightly differently .I really don't know myself .All I did on my AV was cut the cylinder and work on the exhaust port
Thanks Doc! I doubt it will man. So far.... But I doubt it will.Your rear covers are super slick.
Hopefully your plating holds up.
Aftermarket Cylinder Quality
Well… Got burned using a Hyway jug on an 028S. The original jug had some scoring, and the saw was a homeowner saw who only cut a few cords a year. I cleaned up the band on the lathe, cut base for squish, widened exhaust, raised transfers and did my best to fix the horrendous intake port...opeforum.com
