Stihl 031 AV Conversion
Ed Prater
OPE Member
3:28 AM
Botkins, Ohio
Hello, I am new to this Forum, first time posting. I am seriously thinking of taking the points and condenser out of this 031, and replacing it with the little electronic ignition module. Has any of you ever done this, and if so did it run better or worse. I would like some input and advice before I undertake this task. Thanks ed
TALLGUY
2:28 AM
VERMILLION SD
I have never done a 031 but I just finished a 032av and it runs great. I have read that the 031 had two different flywheels with different timing. I used the Oregon module marked Nova 2 worked great.
Nitehawk55
3:28 AM
Ontario
I don't think you will have a problem with it unless it had an electronic flywheel but if the saw is original as it is I see no problem .
NorthcentralYooper
3:28 AM
Upper michigan
I did this to a stihl 020 av , I didn't want to mess with the points and condenser so swapped out the entire coil to a electronic ignition coil. Ran real good
cgraham1
12:28 AM
Nor Cal
If anyone needs a cylinder and piston for one of these, let me know. I have a good one.
Ed Prater
OPE Member
3:28 AM
Botkins, Ohio
I completed the conversion from points to electronic, also changed all the fuel lines while I was at it, and I am happy to report it was a success, the 031 is running great, thank you all for the input, but this isn't the last you will hear from me, I will be bugging you all from time to time for more information, thanks again, and happy new year to you all.
cgraham1
12:28 AM
Nor Cal
Good to hear. It's always nice when a project works out. Happy New Year!
hoskvarna
2:28 AM
Iowa
I put a nova2 on a buddys 031 and it wont run.
Was told i need the electronic flywheel.Got a flywheel but havent got it on to try it yet.
They say the timing is different between them?
Mark71gtx
3:28 AM
Fuquay Varina, NC
@hoskvarna did you ever get the 031 running? Does it have spark? The Nova chip hooks up backwards on that saw compared to most. If you don't have spark, switch the leads. If you have spark and it still will not run, check the flywheel key. When I got mine the key was sheared where someone didn't tighten the flywheel properly at some point. I hope this helps.
hoskvarna
2:28 AM
Iowa
Have not messed with it had some issues of more importantance. Kinda on backburner now. Thanks
From the Hills
Mark71gtx
3:28 AM
Fuquay Varina, NC
No problem, just wanted to throw out what got mine to work if it could help you.
hoskvarna
2:28 AM
Iowa
Thanks
From the Hills
Mark71gtx
3:28 AM
Fuquay Varina, NC
I have bought several on eBay. I am sure many suppliers sell them as well.
hoskvarna
2:28 AM
Iowa
I still have not got to mess with it. My shop burnt down 1/21,the saw was not in it,luckily.
So I have no tools or a place to work on it.
There is a thread started a raffle on here if u want to see some pics.
I did loose 7 other saws among lots of other things!
