- 2:43 PM
- Nov 16, 2022
- Long Beach, IN
I recently acquired a red lever 026, SN 226032139. It appears this one is an early 90’s build from Virginia Beach
Spent a bit of time to clean it up. All parts removed outside of the crankcase in the process. Crank bearings/seals smooth and tight.
Aluminum transfer on the OEM Mahle cylinder came right off using Randy’s method, then porting to widen intake and exhaust ports.
Timing ended up at 96/121/74, with gasket measured .023” squish. Ready to build back better.
