SteveSr
- 11:37 PM
- Dec 14, 2016
- North Carolina
Hello,
I have an 026 recently stripped to the crankcase and rebuilt (mostly rubber parts). Went to run the saw and it starts and idles fine. It will accelerate fine at WOT but when it gets to a certain RPM it dies just like the kill switch was engaged. Once the RPMs drop to near idle it will pick up again and the process repeats.
Anybody seen these symptoms before? I can't believe that a carb defect would cause this behavior so am thinking a bad ignition system (coil). Your thoughts?
Thanks,
Steve
Thanks,
Steve
