Stihl 011AVEQ ignition trouble.
WillG
8:26 PM
Norwich CT
Bosses 011 has no spark, pulled apart and disconnected stop wire and still no spark. Has a funky looking little module on the coil. Anyone with experience on these if it's the coil or module? Is there a modern replacement that works?
jacob j.
Only the weird
5:26 PM
Coastal Oregon
That funky module thing is the 1118 trigger unit - the trigger unit is usually what goes bad. I can't remember if the EQ was a points saw or not, I think the EQZ has the solid
state ignition. If you have a spare trigger unit of some kind (Atom or Nova would work), swap that in first and see what it gets you.
WillG
8:26 PM
Norwich CT
Thanks! Ordered a Stens module to try. I used one on an old Kawasaki powered backpack blower and it worked perfectly. I'll post an update once I get it.
lehman live edge slab
Live Action
7:26 PM
Mn
Ususall
usually if the saw says av it could be whatever ignition but the ave anti vibe electronic and aveq is anti vibe electronic quick stop.
WillG
8:26 PM
Norwich CT
Installed the Stens module and still no spark. Called local Stihl dealer to see if an electronic coil is available.
jacob j.
Only the weird
5:26 PM
Coastal Oregon
I think I have one I can send you.
WillG
8:26 PM
Norwich CT
Boss ended up buying an el cheapo coil from eBay/amazon and I installed it and now we have fire but it won't pop, even on mix down the carb. This thing is driving me nuts! Grrrr. @jacob j. I will send you a PM.
