Agent Smith
Hack of all trades
- 8:31 AM
- Jan 28, 2018
- Northeast ohio
Nope. Why?Um you don't use that everyday...do you?
I did muffler mod on my Husqvarna 44, it really woke it upPics first.
Others will chime in.
Whole thread on muffler mods here
Surprise us. Dont go too big.
Enlarge the hole to the back of the deflector. It lets the heat out plain and simple.
Make sure you wash out all the metal chips.
Only leak I could find was the compression release , it could have been the base gasket, I deleted it , holds 7 psi for 2 minutes easy , vacs falls a bit but not much,Lean. Vac test it. Find the leak
I'm still a little confused on vac n pressure test ,, how the hell can a saw leak on vacuum a little but hold 7psi pressure for 5 minutes???Lean. Vac test it. Find the leak
I know, I turned crank and pressure held fine,Keep in mind that every cycle the seals, gaskets, etc face equal numbers of pressure and vaccuum forces...
But will leak on vacuum every time.
It's driving me crazy.
Saw absolutely runs perfectly, no lean out at full cut , made about 10 cuts with it yesterday.
Think I should retest vacuum after I ran it??
Sent from my SM-G955U using Tapatalk
Cannot find leak , it has to be the decompression release, where you get your plugs to delete themRemove the decomp and install a plug. If you did that already it needs seals or a case gasket. Could be the carb or impulse line. Find the leak.
Just use some teflon tape and plug the hole with a pipe plug. They sell plugs everywhere. Just match the threads and don't crank it down too tight. A short bolt with teflon tape will work in a pinch. Most of use and have extra plugs from cylinder kits. They have a flat washer seat on those. Your dealer should sell the correct plug to eliminate the decomp. You can make one with an old decomp valve and a welder or have one made up locally.Cannot find leak , it has to be the decompression release, where you get your plugs to delete them
It will hold 20 secondsUsually you can just spin the decomp back-and-forth while holding it out and it will make a seal long enough to do a vacuum check. If you look at the needle for five seconds and it doesn’t move, that’s all you’re looking for. A saw that won’t run correctly won’t hold any vacuum at all
