Squish band cutting questions
Termitebuffet
Home of the corn can muffler .....
2:30 PM
Midgetville Norf Kacolacky
Do it got much pitchers?
wcorey
2:30 PM
ma usa
Wow, up to #30 already, my newest one is #23, probly mid 80's vintage.
I doubt much has changed, from my perspective anyway...
srcarr52
2:30 PM
Iowa City
Ummmmm ......
I run about 325 rpm, thats the lowest mine will spin. It’s not a constant cut, you have to also consider that if a cylinder isn’t balanced, the fastet that you try to spin it, the more your whole machine can vibrate or shake
I spin them at 500, I'll spin them faster if they are not terribly off balance. Surface speed is needed for clean cuts in aluminum.
High rake tooling helps a lot too. I use a positive rake 32.51 CCGT carbide in a 1" carbide boring bar.
My squish cutting plate is 4.5 square by 1". I drill 1/4x20 holes and make any stud I need from all thread. Most of the ones I use are turned down on the cylinder end and threaded for M5 nuts.
twinstaged
2:30 PM
Ohio
You can make out what insert that is here and look at some other options. Several pages in this book dedicated to holders and inserts.IMG_7464.JPGIMG_7467.JPG
Outback
11:30 AM
Oregon
Thanks again guys. I've been grinding my own HSS for a year now. Sharpen a lot of tools also, have various stones for after grinding. Fully aware of the benefit of aggressive angles/clearances on aluminum. The carbide inserts I have are speced for aluminum.
I chose the insert bar because I mess mostly with huskies. I imagine D chambers are a little interrupted in the cut but not the hemi's so much. I use the HSS for the bases.
I saw a couple base pictures on here recently that were smeared and not shiny. I'm not calling anybody out as I know very little. If your cut speed isn't high enough and cutter angle, the aluminum sticks to the cutter tip also aiding in the fog.
srcarr, I also like to overbuild it once. ;) As always lots of good info guys.
srcarr52
2:30 PM
Iowa City
I've found that some cylinder material just doesn't like to be cut cleanly. Even the factory cut is smeared. The 365/372XT cylinders is a good example.
I've tried faster RPM, more rake, deeper cuts, skim cuts, ext. Nothing seems to help.
thomas1
┌∩┐(◣_◢)┌∩┐
2:30 PM
Cristobal Colon
Poor casting density, perhaps?
Outback
11:30 AM
Oregon
Cheap alloy? I do really appreciate all you guys are adding here. Except for feeding me MAD to go with the CAD. The want for a bridgeport just grows and grows. Thanks deets.
srcarr, Did you ever try any PCD? Diamond tooling is supposed to do wonders with aluminum. I have never tried any.
srcarr52
2:30 PM
Iowa City
Not for this applications, inserts are really expensive and often need a special tool holder. But I'm not going to spend $300-500 to get a better surface finish that I don't really need.
The automotive machine shops I've worked at use CBN or PCD pucks for head gasket surfaces, especially for the newer multi-layer steel gaskets.
