Outback
I've done a couple of cylinders on my lathe with popups and now I want to compare cut chambers. I've got an indexing boring bar on the way and a long reach horizontal indicator. I was looking at 1" x 4" t6 flat bar to make mounting plates out of. Too thick or just right? Wider? Is all thread with nuts the way to go or can I get away with cap screws into threaded t6 as they aren't tightened heavily. How tight are you guys cinching them down? How much torque to break a corner of the base off generally? Any advice, tips, or tricks to cut down on first time errors would be appreciated. Thanks guys.
