- 8:58 AM
- Dec 3, 2015
- Banner Springs Tennessee
Jon was making some damn slick running .325 on it. Now we have to start over.
I've not filed any of the .325" square. I need to try it. I've got a loop on my 346 since the hippy sent me some 18" .325" bars.Jon was making some damn slick running .325 on it. Now we have to start over.![]()
I disagree with the first part. The top plate underneath angle makes the biggest difference in cutting speed. The less defined corner is weaker like round chisel. I like the 30° angles.Randy, I don't see much point to the Goofy, it results in a round side plate, the most important part of square, and a less defined corner.
Use the double bevel, try to keep in at about a 45 degree slant (to get the side plate right). I also drew 45 degree lines on my sharpening box to help me get the angles right, and your file will touch the top strap on the opposite side, which will also help to guide you.
W/o the lines on my box to guide me, I kept reverting close back to the old 30 degree angles, not a good thing.
I don't doubt it at all. Some of the semi chisel is real slow.Mike a friend did RS to square in 325 and it was 50% faster then the RM it replaced on a 290 I was doing.
Was done on a modified swingarm.
MustangMike posted a link in post#134 about the angles. Helps explain the angles. Explains what's good and what's not.i just use plain ol boring LGX and husky round files. allows me to complete my firewood hacking duties in an acceptable amount of time. saw kevin do some square filing with good success a couple weeks ago. i may get into it just out of curiousity, i dont know enough about all the different angles and the consequences of messing them up.
thanks dude i shall check it out.MustangMike posted a link in post#134 about the angles. Helps explain the angles. Explains what's good and what's not.
Sounds like Jon should have entered the PS chain build in work class.
Nope no fussing or fighting. That was the 3rd chain build done wasn't it? Hedgerow had one last year that wasn't a fight either. Way less drama than a saw build for sure.Nope not on my site.![]()
Can ask anyone involved in it.
Huh Mike.
