- 12:39 PM
- Feb 18, 2019
- NOVA
I think @Dolkitafreak has a stash of the vallorbes he would be willing to share for a reasonable donation.
Welcome to the forum!Are the same files used on a full chisel as semi chisel?
The same round files are used for full-chisel and semi-chisel chains, when they are sharpened conventionally.
This thread is focused on special files for ‘square filing’ cutters, which is a niche method, and can only be done on full-chisel chains.
Philbert
Thus part makes no cents. What kind of chain are you trying to sharpen?So if I try a chisel chain I can use a round file. Or should I say try to sharpen with a round file.
I'm new to any chain beyond standard safety chain
‘Safety chain’ is a bad term to use. Reduced kickback chain is made with both full-chisel and semi-chisel cutters, although, the latter is more common.. . . if I try a chisel chain I can use a round file.
Please post a photo of the chain you are referring to. There is FULL chisel and SEMI chisel. Both chains being equally gauged should use the same ROUND file.
Not any more than usualYou guys will be hatin on me like usual when I invade a square thread.
