So what did you buy today
NateSaw
8:13 PM
Maryland, USA
and how much is too much now? I recently saw one in working order here for $333 / The correction in this price was Ms 044 and the newer Ms 440 is an expense for us at least. $500
I paid 400$. It has Chineseum carb, recoil cover assembly, clutch cover. Repaired fuel tank, roached handle bar. So I got a decent short block. No fasteners stripped. Ultimately, I should've just seen if anyone on here had a case with crank. I've already purchased a good used tank assembly, 460 KS top end, air cleaner cover. I plan to use one of the 2 461 carbs I have. Long story short I'll have a ton of coin in this saw when it's done. I had gone to look at a few "parts saws". Both of them were just roached. Bolts stripped, cranks wasted. Idk what people do to saws to get em that far. Long before they're that trashed, they stop doing the work needed. Idk.
Partner
2:13 AM
Poland
the $5 screwdriver is 29 years old and looks like new, I will try to charge the batteries but I would rather replace the cells Bosch PBM 7,2 VE-1
NateSaw
8:13 PM
Maryland, USA
It's not what I bought today.. My buddy Eric found this specimen for way too cheap! He had one years ago and lent it out. You know the rest of that story. So I did a build thread on here of his 044. This early 026 rounds out his arsenal... 20231023_173045.jpg20231023_173033.jpg
That's a happy bloke right there! He and I had been looking for a while. Specimen!
Partner
2:13 AM
Poland
The grinder for a few dollars is 28 years old and the engine is barely used because one of the brushes is stuck. Plastic gear housing and the motor is larger than the new Bosch 1000W
Philbert
Chainsaw Enthusiast
7:13 PM
East Dakota
31.50 Shipped,
Yeah. Seemed stupid expensive, compared to a file. But once I had it, I really liked it.
There are cheap eBay ones, that are not as good. We discussed these quite a bit in a thread on A.S.;
Philbert
Squareground3691
8:13 PM
New England
Philbert
Yea , been using Vallorbe brand products and files for over a decade, and haven’t looked back,👍
Partner
2:13 AM
Poland
a few small items for $20 / floating knife Barakuda , tin sucker Soldavac Ls 165 insulation stripper from thick wires Kaiser amz1, Stihl chalk
legdelimber
8:13 PM
N.C.
Any signs of bad commutator arcing damage, as the stuck brush wore away?
Check any solder work and wire varnish on the rotor windings for over-heating as the brush wore away.
You probably are doing this, as you seem to work with the used tools pretty regularly, but others may not be aware of it
Happy tool hunting!
Partner
2:13 AM
Poland
Happy tool hunting!
This is what would happen if the operator used it forcefully, but there is no sign of damage / sometimes someone notices that something is wrong and puts the equipment back on the shelf
