Redfin
Meh...
- 3:40 AM
- Dec 24, 2015
- Central Pa
You are still side loading the bearing with your tool.Or just use one of my tools to get it centered
Never bbq a cat. Im not opposed.Yep....
Many ways to skin a cat. And they all work just fine.
I have a brass drift pin that I use without a hammer to center the cranks.I have a well worn brass hammer......it's number one use?
Bumping cranks.
Never have had an issue out of literally hundreds of saws.
Nice escaladeView attachment 74834
Had to finish this up for a job tomorrow, no saw work today
No room
What if ya took a cheap crank...turned the flywheel side lobe into a cutting surface by either adding sandpaper or putting a lot of burrs on the surface of the lobe with a grinder and a chisel? I dunno.
Lmao so anymore progress deets
This is a $20 Asian crank, I ain't afraid to beat the piss outa it.![]()
