Slanted 660
Deets066
AKA Deetsey
2:28 PM
I'm an electrician
I can weld
Angle grinders are my friend
Did you know it was an electrician who invented the angle grinder to make his welding look good :)
The way I was taught....
Get good with a welder, get good with a torch.
Or, get good with a grinder.
I like the first two way better than a grinder
Backtroller
1:28 PM
Land of Badgers
I ran a purdy one just for you Pat
Nice, I know I'm weird but as a kid I use to stare at the tig welds on my bike. Then it was the welds on my headers. I need to get a nicer helmet and practice with my mig. Shouldn't be a problem with all of my extra time.
Deets066
AKA Deetsey
2:28 PM
It's 75 percent setup and equipment. The actual welding is the easy part. Learning your machine and what it's capable of comes first
Deets066
AKA Deetsey
2:28 PM
how in the world would you test that to make sure you didn't add too much? once I put a crank through a bearing, thats it. .... so... just a good guess?
is it the 064 cases that have less case volume...so, is that what you are going towards here?
Anytime I've raised case compression and or transfer velocity I've noticed a gain.
Didn't test, or measure, just winged it.
Mattyo
Youtube speciawist
2:28 PM
Farmington, CT
what ya *could* do... is take an old bearing, put it in the case, pull the crank through with some sandpaper glued to it...and machine the surface down.... ifn ya wanted to get fancy
