- 11:36 AM
- Jan 17, 2016
- cape cod ma.
Missed ya in Ct this year Bro.
Missed you guys as well. I was in Indy for a Mecum car auction and at the
Indy race track Friday.
What rear end gear ratio you got in that truck?
I had great luck with my ‘06 5.9. I still kinda miss shifting my own gears, too...View attachment 185629 plain Jane..no frills 3/4 ton
Awesome...this 6.7 has been great ever since I let it start breathing, bumped the fuel up and advanced the timing a smidge....I had great luck with my ‘06 5.9. I still kinda miss shifting my own gears, too...
Well. This happened last night.
I’m starting to think I need to delete the DPF & DEF systems.
Headed for the dealer (two hrs. away!)... message popped up that it was “cleaning exhaust filter” and the DEF fault message went away. I’m dropping it off at the dealer anyways.
I guess we’ll take my dad’s old 6.0 Powerstroke/ZF6 truck to Montana, and the dealer can have my truck all week. I was looking forward to taking my truck, but I guess it will be fine.
Do you drive a lot of short distance trips? Idle the truck much?Told the service writer what was going on and he thinks with the frequent regens and DEF fault that the DPF might be partially plugged... he wouldn’t say if it was something that would be covered by warranty or not.
This is a big dealership and he said it’s very common... I guess trucks come in for this same thing all the time.
That sucks. Deletes may be your best bet or trying to lemon law it.
I would think that is one of the things they will be checking for... especially since the service writer mentioned it when I was dropping off the truck.Do you drive a lot of short distance trips? Idle the truck much?
Biggest problem with the newer def and egr systems is that the trucks equipped with these systems don’t get worked hard or driven any real distance for the systems to fully get up to temperature.
If you’ve had turbo issues previously this would also contribute to a plugged up dpf filter. I’d be asking the dealer if the filter is soot loaded or ash loaded.
