Sharpening Chain.
Farmchuck
10:42 PM
Nepa
The instruction manual for your grinder should show you how to center the chain holding vise to get equal length cutters.
This setting can change as the
grinder wheel wears and the diameter changes.
Or, you can adjust your technique: I will grind all of the Left cutters (for example), then do just one Right cutter. I stop and compare that cutter back-to-back with one of the Left cutters, and make small adjustments to the cutter positioning stop / dog to get equal length cutters.
After a while, you will be able to predict which side will be longer without making the adjustment.
Philbert
With what do you compare them with?
dahmer
10:42 PM
Ellwood City, PA
See photo in earlier post. You can measure with a micrometer or caliper, but visually is good enough for me.
Philbert
Haven’t been retired long enough, even if it isn’t super critical I keep cutters +- .005”, gives me something to do.
dahmer
10:42 PM
Ellwood City, PA
Do you set your rakers with the same precision?
You got me thinking on this. I have a bar clamped in a vise for doing rakers. I can mount a magnetic indicator base to the side of the bar and just swing the indicator over each raker as I file it. Give me something else to do. Thanks for making me think @Deets066.
10:42 PM
No sir. All set. TY
Deets066
AKA Deetsey
10:42 PM
Don’t think so, they need to be set as opposed to each tooth.
Deets066
AKA Deetsey
10:42 PM
Let me know if you figured out a better method than a parallel and a feeler gauge. Cuz that sucks
dahmer
10:42 PM
Ellwood City, PA
Will have to mount indicator base on anvil of vise for it to work correctly. Mounted on bar will not work because of angle.
dahmer
10:42 PM
Ellwood City, PA
Supposed to rain here Thursday and Friday, I’ll work on it then. Can’t let the leaves get too far ahead of me so it’ll be at least Thursday before I can start experimenting.
Philbert
Chainsaw Enthusiast
9:42 PM
East Dakota
